Old 07-02-2011, 04:48 PM
FFR428's Avatar
FFR428 FFR428 is offline
Cobra Make, Engine: HM-2027 / 427 SO
Doug those heads have the right location and port size your looking for. Same as early lowriser. That said be aware they are not a matched set. One is a big R cast at the Cleveland foundry (CF) and the other small R cast at the Dearborn foundry (DIF). There are some small differences but nothing major I'm aware of. Ad also states he's not sure what valve springs are in them or max lift. That would need to be checked against the cam your using to be sure they are compatable. Other than that they look like a nice set of heads.
BTW there's a usede set of Edels on FE.com. Looks like the rocker stand bolt holes need new helicoils but you might be able to deal with him a bit. He's had them for sale a while with no bites. If I see anything else I'll let you know.
