Old 07-03-2011, 02:07 AM
belgiumbarry belgiumbarry is offline
Originally Posted by Gaz64 View Post
Wise to paint a stripe across the inner hub/rubber/outer hub on your new balancer before you replace it.
Then you can monitor the ring status in relation to the inner hub.
Great idea ! i have also a service hole in the bellhousing ... which is directly visible for timing light check....gonne paint there on the clutchplate a stripe at TDC.
For the balancer i have to remove the firewall lining ( belts and some screws , audio cables... ) and behind that a door with some bolts... lucky it can be done with the seats canted and most to front position....
