Old 07-03-2011, 04:24 AM
cobrajeff's Avatar
cobrajeff cobrajeff is offline
Default Timing marks for a Pantera
Once you get the timing marks straightened out on your balancer, I would recommend painting the same (TDC, base time, full advance) marks on your flywheel, through the inspection hole in the bellhousing,and paint a pointer stripe on the center edge of the hole to align the timing marks to.
Makes checking and adjusting timing on a Pantera much simpler - you won't have to pull the seats or rear panel out to do it - just point your timing light at the bellhousing inspection hole.
regards,
Jeff
CobraJeff
ERA P 202
