Old 07-03-2011, 04:24 AM
Default That puddy can get removed
767 Jockey Remove the puddy and have larger timeserts installed in the heads. Very easy to do. As long as a sealer is installed on them vacuum or exhaust will not leak out. My shelby heads have this done to them when a broke the 1st rocker shaft at Gateway. Have to watch the oiling hole to the heads and I grooved the ARP studs to the rocker stands.
Call the guy and ask about any other head work done to these heads?? Milling, cracks, when the valve job was done, how many hours are on these heads, you know check out questions.
Send them to my house I will do the work and send them to Ed.
If you get them for a good price, buy them. Have a good holiday Rick
