Old 07-04-2011, 04:21 AM
Default Aluminum not allowed in some states
Wisconsin_Snake, Snake some states will not allow aluminum lines on the roads. Vibration and road debrie are the main issues. Need to check with inspection stations in your state. IF you can run it, make sure you have a rubber clamp every 12-16". I also have mine in a clear plastic hose under the car. This protect both lines from the tank to the motor. I have 2 255 liter pumps in the tank for my FI system.
You need 2 lines, (1) 3/8" supply line running to front of car and one 5/16" line return. As far as the fuel pump, put one inside the tank if possible. Some pumps don't have good suction to pull the gas from the tank unless you have a sump in the back of the gas tank to mount the pump at. Bad thing is if you are hit the the rearend, Lines and pump are exposed.
The other problem is rubber fuel lines. The methonal is eating the rubber. We have 10% going to 15%. Plastic or steel lines are in all cars nd trucks now. I have had to replace rubber lines in my others cars with resistant to methonal.
Not 100% sure but the new hose is a grey outter color.
What ever you do, make sure the lines are up and out of the way, protected from heat, and clamped to the frame.
If you can double flair all connections, no pressure couplers. They crack and cruck the steel or aluminum lines and can cause leaks. Good luck Rick L.
