Old 07-04-2011, 12:22 PM
patrickt patrickt is offline
Originally Posted by Murky781 View Post
Adding to this thread because I have NO SPARK. 69' 428, MSD-6AL, replaced coil, voltage reg. ignition switch. Did the paper clip test on the MSD, it was good.
When you do this, what is the result? Do you get a spark to ground?
1. Make sure the ignition switch is in the “Off” position.
2. Remove the coil wire from the distributor cap and set the terminal approximately 1/2" from ground.
3. Disconnect the MSD magnetic pickup wires from the distributor.
4. Turn the ignition to the On position. Do not crank the engine.
5. With a small jumper wire, short the MSD’s Green and Violet magnetic pickup wires together several times. Each time you break this short, a spark should jump from the coil wire to ground.
