07-04-2011, 06:10 PM
IL
Cobra Make, Engine: Everett-Morrison, Pushrod 16 valve V-8, Aluminum block/heads, GM engine-control system with port fuel injection
most likely your ignition switch is going south. Try wiggling the key next time usually helps align the contacts.
55 mph is unsafe.. its fast enough to kill you, but slow enough to make you think your safe...
