Old 07-05-2011, 10:17 AM
Jimbocobra's Avatar
Jimbocobra Jimbocobra is offline
Cobra Make, Engine: Backdraft#357, 392CI Ford Racing, 459hp, 455ft/lbs , TKO 500, 3.43 Gears, Ceramic Coated Headers, Victor Jr. 750cfm, 17in Halibrand wheels, Sterling Gray/Silver Stripes, Gray Leather, Nitto NT05
Default Tko fixed
Originally Posted by Tugboat View Post
Wow, just finished fixing this problem last Friday!!! Also Google TKO 600 stuck in gear and you will find lots of info on the WWW. The Chevelle forum had the best info.
I took my car to the Big Bend Open Road Race a few weeks ago and on the third practice run my TKO600 stuck in 4th gear. Yes there is a quick fix but will reappear. I had Rosehill Performance here in Houston take the trans apart and fix it. He found the shift fork bumpers, little plastic things, were destroyed from shifting hard. He replaced them with bronze ones and then removed and rebuilt one of the shift gates that has to be beveled a certain way. $400.00 later it is BETTER than new. After hours of reading on the internet this problem seems to be with tremecs produced around late 2006 and early 2007. The TKO 600 was new at that time. I personally know of three Cobra's that have had this problem. Seems like alot in our small world.
Larry Boatner
Liberty Gears described the same problems as above and did a similar fix. I also had some bent shift rails that were replaced. Those plastic "things" were worn out and caused damage to the metal they were lining. We sent them the parts and they replaced and repaired them with stronger ones, no more plastic... I took it racing and had no issues at all, problem seems resolved and is stronger than new. There was no internal damage to the transmission, just the shifter linkage.
1/4 mile 11.92@115.6 and 60ft 1.632
