Old 07-05-2011, 10:20 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
It has been my experience that the positive is voltage, the ground is chassis and the third wire goes to the meter.
Didn't they give you wiring instuctions?
If there is a biasing resistor or box, it would be called out in the instructions.
Biasing would allow an accurate reading over a wider voltage range like 8 - 16 V.
This means the meter voltage would be much lower...hence not pegging the needle.
Just my worthless opinion.
