Old 07-05-2011, 05:13 PM
jhv48 jhv48 is offline
If no luck with pulling hard on the handle, you might have to loosen the adjustment nut on the end of the rod. Crawl under the car and loosen the four bolts that hold the passenger seat in place. Lift out the seat and then pull back the carpet from the brake handle. You'll see a small nut on the end of the brake rod. Loosen it and the brake will release.
Jim
