Old 07-05-2011, 11:18 PM
FatBoy's Avatar
FatBoy FatBoy is offline
Cobra Make, Engine: Kirkham #523, 427 S/O
I used a pair of standard dry cell batteries the same as those used to power pedestrian buggies as used by the elderly and infirm.
These are generally all black and as they are dry cell, have no caps. However, being dry cell also means no acid, which has to be a good thing.
I masked off the top and spray painted the main case white. I then made up some labels in MS Publisher and printed them onto some Avery vinyl labels. If you PM me your email address, I'll send you the image file so that you can print some yourself.
The final requirement was the caps. I used the tops and threaded necks from soft drinks bottles. Cut the neck off right beneath the strengthening ring and sand it down smooth and flat, this provides a nice flat surface for the glue and then paint them black. If you get the right drink brand, the caps are already orange, or you can paint them whatever colour you want.
I left a gap between my caps, which meant I only had room for 5 on each battery, but 6 is possible.
Here are the finished batteries:
..and here's a close up of the caps:
Paul
