Thread: FE timing
Old 02-04-2002, 02:59 PM
Toivo's Avatar
Toivo Toivo is offline
I'm a bonehead!
Originally posted by Cobrabill
Aluminum headed 427 made the most HP on the Dyno when timing was at 44 degrees.
What kind of domes were under these heads?
When you need 40+ degrees of timing it usually means a sloppy flame-front, usually caused by monster domes in the way.
So, are you running domed pistons? Why else might you need 44 degrees of timing?
Thanks
