Old 07-08-2011, 03:25 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
My primary concern is not so much with the bar design itself but rather how it might might utilise the door jamb to stop the whole bar entering the cabin. What's the point of a strong bar atteched to fibreglass.[/quote]
Most cobra doors use Ford rear door catches or similar not even designed for side impact in front doors....These catches are only held on with three 1/4 inch bolts. All the side intrusion load comes down to the size of these bolts. Its alright to have big heavy bars in your doors but these bars in the doors will spear straight into you after the three quarter inch bolts have shorn off... In a car the doors carry on past the pillar and in side impact the door carries the load all the way up on the pillar all the load is not exerted on the catch.... unlike a cobra were it is...
