Old 07-09-2011, 05:47 AM
Zedn's Avatar
Zedn Zedn is offline
Originally Posted by PeterAllen View Post
That sound something like what I want but I just can't figure out exactly what you mean. Could you post some more photos that illustrate the setup. Thanks.
Here is what I have at the moment. I have cut out the inner panel and will replace it with with a sheet of aluminiun with a few rolled ribs. I've made some inner spreader plates for the door hinges and that's about it, so far.
What about replacing those spreader plates with a piece of 5mm x 50mm flat bar extending across both hinges. Bend the 5mm bar to follow the contour of the door, then butt weld 2 pieces of 32mm x 4mm steel tube running as the intrusion bars. Add a gusset welded at 90deg to the 5mm flat bar to brace the butt joint. Then do similar on the other end for the latch to attach to. (just an opinion, no responsibility taken!)
John Wilson recommends 32x4 tube on his website:
Newsletter
Does it use the datsun frame for the hinges and striker plate to mount to?
