Thread: 302 Rebuild
Old 07-09-2011, 03:11 PM
07cob's Avatar
07cob 07cob is offline
bobcowan
Thanks for the reply. Unfortunately, a crate motor is not really an option with our registration requirements.
Here is the TrickFlow heads and matching cam that will be installed:
Trick Flow® Twisted Wedge® 170 Cylinder Heads for Small Block Ford: TFS-51400004 - trickflow.com
Trick Flow® Track Max® Hydraulic Roller Camshafts for Ford 5.0L: TFS-51402000 - trickflow.com
This combination has been used on a few engines over here with some very good results. Bear in mind, I am not trying to make a big HP engine – just a slight upgrade from stock.
Originally Posted by bobcowan View Post
The TW heads have a chamber volume of 64cc exactly
The TrickFlow website quotes 61cc for the 170s.
You're going to put a new top end on a 20+ year old bottom end. That's fine if you plan on doing this job again in a couple of years. If you want to do it once and forget it, you should consider a new bottom end.
What would you recommend for the rotating assembly?
Geof
