Thread: 302 Rebuild
Old 07-09-2011, 03:14 PM
07cob's Avatar
07cob 07cob is offline
blykins
Thanks for your thoughts.
Which Trick Flow heads are you using? Keep in mind that if you use a twisted wedge head, that you'll need different pistons.
Also, keep an eye on piston/valve clearance. Those 5.0 engines don't lend much in the way of room and if you go much over .500" lift, you'll run into some issues depending on the camshaft.
The heads are TrickFlow Twisted Wedge 170s (PN: TFS-51400004).
These have been used on a few SBFs here with no change of pistons.
TrickFlow website also states, “Trick Flow® Twisted Wedge® heads are the only aftermarket heads that can run 2.020 in./1.600 in. valves with stock, unmodified pistons and performance camshafts up to 0.550 in. lift” (Trick Flow® Twisted Wedge® 170 Cylinder Heads for Small Block Ford: TFS-51400004 - trickflow.com)
Regardless, I will heed your advice and check the clearances carefully.
While you have it out, it would be a really good time to put new rings and bearings in it, along with gaskets and a rear main seal.
Thanks, I am tending towards doing at least the rings and bearings while the engine is out. Also, every (?) gasket and oil seal will be replaced.
Geof
