Old 07-10-2011, 10:41 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by Michael C Henry View Post
I now have a 14" LongAcres racing mirror. I want to mount it inline with the top windsheild frame. I have the sunvisors so I need to mount mirror to the rear and under the visors so I can lay them flat when the car cover is on. any body have an idea or seen anything I can use?
I fabbed this mirror mount, and it works pretty good. I'v since remade it to look a little bette; prototypes generally don't look all that good.
I made thse bolts useing a threaded rod and square nuts. I welded the nut to the threaded rod, then shaped the nut so it would fit in the window channel. The other end uses nylock nuts.
To install, simply slide the ends into the top window channel, and tighten the nylock nuts. On and off in a couple of minutes.
I believe Darkwater sells something similar.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
