Old 07-10-2011, 07:09 PM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Originally Posted by bobcowan View Post
I fabbed this mirror mount, and it works pretty good. I'v since remade it to look a little bette; prototypes generally don't look all that good.
I made thse bolts useing a threaded rod and square nuts. I welded the nut to the threaded rod, then shaped the nut so it would fit in the window channel. The other end uses nylock nuts.
To install, simply slide the ends into the top window channel, and tighten the nylock nuts. On and off in a couple of minutes.
I believe Darkwater sells something similar.
The Broadway mirror is excellent. Comes in various sizes and really works well just clipping on any existing mirror in the stock location. Some cars just have way too many mirrors in different locations...looks like the mirrors are stacked up in a landing pattern.
Doug
