Thread: Spring Rates
Old 07-12-2011, 05:29 PM
RET_COP's Avatar
RET_COP RET_COP is offline
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
Default Spring Rates
I wanted to stiffen my rear as it tends to bottom out on the snubbers at times when I use a lower ride height. I have carrera hypershocks with QA1 8-375 front and 10-185 rear. This was what came from B&B. I called QA1 and they recommended 225lb rears which I ordered. I'm not actively racing the car but a stiffer ride is better than a soft ride to me. I looked at front springs and QA1 offered a 500lb for the next step up. This sounds too stiff as my front seems good at the moment. I don't plan on running a sway bar. Is it true that there is about a 2 to 1 ratio front to rear on spring rates for our cars, excluding racing setups? What are some or your setups so I can get a idea on this matter. I've seen spring rates all over the place but I'm really asking about B&B cars since different geometry's can alter rates.
Thanks LOU
Lou
