Old 07-13-2011, 06:34 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Do you have an inline gas filter? If so change it and also change any other gas filters you may have in your fuel line. I run a Holley gas filter before my electric fuel pump (located near my fuel cell) and then I run another inline filter before my fuel regulator. By the way your fuel pressure should be about 6.5 pounds. If that doesn't work remove your inlet fuel lines and see if you have any screens at your carb inlet with some debris in them. I would also pull my carb off and remove each of the jets and spray them and the carb with some carb cleaner. If all that doesn't help then I would change my headlight switch!!!
"Let's roll"
"Be part of Something Good
