Old 07-13-2011, 08:11 AM
RodKnock's Avatar
RodKnock RodKnock is offline
Originally Posted by fordracing65 View Post
On the street no way, around corners no way, down a prepped drag strip with slicks, depends on the driver.
Did you have a point here? What's my point? Honestly, I would stop "taking a leak" on Barry's thread, stop stating the obvious, stop with the big block versus small block nonsense (though we haven't had a good BBF versus SBF in a while), and if you had a point, you made it, and move along.
Here's my point, in case you missed it. Yes, we all know it's an expensive engine. So what? Barry built a beautiful expensive engine, and then you're saying it's expensive (duh), FE's can't handle and FE's can't get down a track fast enough as, maybe, your car? Really?
Resorting to name calling? Really? BTW, trolling is trolling. You're trying to incite "the masses."
Also, if you have a Kirkham, then you should change your info in the top right hand corner of your posts. It still states SPF.
