Old 07-13-2011, 02:40 PM
Outwest34au's Avatar
Outwest34au Outwest34au is offline
Cobra Make, Engine: Evans kit, 6 litre, 6 speed, Jag F/R,
Just out of curiosity...my vehicle has intrusion bars...a Ford approved latch and matching catch...bolted securely to the chassis. The 3 bolts (screws actually) holding the catch are pretty small about 6mm / 1/4" so all depends upon these three bolts. On a steel body the door fits into a "socket" so along with the catch the door crushes up against a pressed and folded steel frame which helps in absorbing an impact. Fibreglass frames are stiff but how stiff ?
Re the socket and pressed frame, if I had a 32 mm CHS bar running along inside the door frame on the sill panel I would feel the system would be as good as it gets, something to stop it moving in. The door in a car like ours is only there to fill a hole and any load in my opinion has to be spread to the chassis, be it through the front hoop or direct to the chassis at the latch end.
Drive the Cobra like it was a motor bike...be aware and be defensive.
I said that to my workmate as we drove home last night.
ADRs are for compliance, vigilance is for life.
Missed my Cobra budget by thaaaat much.
Ya get that on big jobs.
