Thread: Spring Rates
Old 07-14-2011, 01:31 PM
RET_COP's Avatar
RET_COP RET_COP is offline
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
mbeer6 remember there is the length of the spring and the rate. Going to a softer rate may cause the rear end to hit the snubbers on a bump. Going to a softer rate may not work well with the rate of the front springs. If you have a 12 inch spring that may be your problem, a 10 inch would correct it and allow you to lower the ride height and get the adjustors higher on the shock. There is alot of science to this shocks included, but I tried to make a simple move and just went up in rate.
My suggestion would be to pull out a spring and look at the length and rate and get back to us. Take a measurement of the rear end housing to the snubbers, how high the adjusting coller is on the shock and the ride height [space between the top of the rear tire to the lip of the fender and length of spring under weight. Wayne and Larry have good knowledge about the B&Bs. At least that is my thinking.
Lou
Lou
