  #32 (permalink)
Old 07-15-2011, 08:12 PM
ptrefry ptrefry is offline
Cobra Make, Engine: Classic Revival 3506
Originally Posted by DaveW View Post
Ptrefry,
Is your CR the older chassis, looks like you have FF upper control arms,
What is the offset of your front wheels,
Have you shortened the original hub or is that standard, as the alloy knockoff hub would push the wheel out further, or do you cater for that by machining the wheel mounting face,
looks great
Hi Dave my chassis is the older style.
The upper arms are FF.
I had to machine up the new hub so that its 35 mm shorter to allow them to fit under the guards.
The Stub axle then needs to be shortened by 35 mm as well.
Its a bit of dicking around ,but i really wanted the knock off centers.
I also had to machine 5 mm of the inside of the wheels to allow for clearance for the calipers.
I would have to re measure the offsets for you .
Vintage wheels have all my measurements for offsets if your interested in getting wheels.
Thanks Paul
