Old 07-16-2011, 02:14 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
I agree with the motorbke theory....
That extra rail youve put in is at seat height.....if something collects you from the side or you slide sideways into something your body is going to be travelling towards the door....you will slide straight over the top of that bar...
an air bag is going to be the only thing that will absorb the impact....just a silly one maybe we should be filling the doors with styrene foam....!
