Old 07-16-2011, 09:23 PM
Pman1961 Pman1961 is offline
Cobra Make, Engine: Superformance SP02423 KCR 445W 611hp 599ft lbs
The clutch fork has two holes we'll just say and inner and outer hole....outer being furthest from the pivot point. I just looked at a pic that B2 sent me a while back with the setup I purchased from him and it shows the rod going through the inner hole of the clutch fork. The original set up (bracket and slave cylinder) was outer hole. When I installed the B2 provided in the outer hole the push rod is way out of alignment. When I relocated push rod to inner hole everything seems to align now. May explain why the pivoting ball at the push rod is larger. That may be solved but would like to see the spring pic if someone has to share.
