Old 02-05-2002, 04:47 AM
CobraEd's Avatar
CobraEd CobraEd is offline
Clois, what is the static timing at idle? If you are only pullind 28 degrees of advance at high rpm, then you are way retarded (the engine). Set the static timing at between 10-14 degrees and try that. Make sure that your vacume advance is hooked to the variable vacume port that only creates vacume when you open the throttle, not the port with constant vacume at idle!!! Also, At what temp did the fan kick in?
Ed
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
