Old 07-19-2011, 01:26 AM
Zedn's Avatar
Zedn Zedn is offline
Berobase is debeers base coat for use under 2k clears. it cannot be used by itself. De Beer Refinish
I have tried something a little different with my chassis. I first sanded it then marine clean, metal ready, por 15, blue pearl base coat, then Glisten PC.
Its kind of a long story why i went this way. I was originally planning on using just silver por 15. When i spoke to the guy at PPC he told me that the silver changes colour overtime and showed me a sample. I was then going to use the sterling silver over the top but found out it is semi gloss. That led me to purchasing por 15, sterling silver and then glisten PC over the top.
After getting it all home, i decided the sterling silver wouldnt give me the finish i wanted as it is not metallic so i decided to use the pearl blue that i am using for the body.
I sprayed it on the weekend and it turned out great until i discovered the base coat hadnt covered properly. I am now in the process of rubbing it back to recoat with the blue.
