Old 07-24-2011, 11:41 AM
dlampe's Avatar
dlampe dlampe is offline
Well I cut the 6 in hole as Doc suggested. I have used JB weld to hold all kinds of things together so it was the option I was the most comfortable with.
After I cut the hole, I found the bolt hung up on the crank. It wasn't in the pan. I'm glad I cut the hole or I might never have found this little sucker. I have an old VW drain plate that will fit right over the hole. I think the JB weld will hold it in place until the RTV dries.
Thanks again for all you help. This is a great forum!
High Maintenance Racing Team
Run & Gun 2003 - 2013
