Old 02-05-2002, 03:40 PM
scratch scratch is offline
greenwater, leadfoot,
Do the headers yourself and save lot's of $
Take 8pcs. of 1/8" all thread and clamp washers (nuts on either side) every couple of inches, or at least where they come close near the body exit.
Have a local muffler shop bend your tubing...stainless is best if you can buy it for them (use thick wall)
Buy the correct flanges (Summit) and mark the angles of tube to flanges (you can grind the tubes close.
Have a welder (or the muffler shop) weld away...taking care to hold the 4 tubes together (I used wire and wood)
@ $300
Coat, paint or polish and you are on your way.
My only problem was using thick wall tubing which was a real ***** to push around into my side pipes.
p.s. grinding down the welds make for future cracked areas...Also, I bought a 12" length of tubing which was one size smaller - and cut several 2" sleeves to join straight areas...made it much easier to position the tubes.
scratch
