Old 07-27-2011, 08:52 PM
RestoCreations's Avatar
RestoCreations RestoCreations is offline
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Ran out of gas a little while ago while attempting to tune the car and it dropped to 2 then to 0 PSI Got fuel, put fuel in car, turned pump on, took screw out of pressure regulator and it dropped to zero. Reinstalled screw and still it only went to 4.5psi in run and around 5psi running. Point of this babble, i think the pressure gauge is working correctly and so is the regulator.
I will take the pump apart tomorrow and try the above fix in the link. Thanks for the help, suggestions, and link.
