Old 07-28-2011, 09:32 AM
Tommy's Avatar
Tommy Tommy is offline
Just speculating Tommy but how do you know it was the pump? Possibly the line near the carb or the carb itself heat soaked as you were traveling slower than track laps??
My experience is that the electric pumps cooler fuel than the mechanical during hot conditions and I always have a good feed.
My understanding is this. If fuel in the line or carb float bowl vaporizes, that bubble will be displaced by fuel from a working pump. For example, if fuel in the float bowl vaporizes, the float will fall, the valve will open and the pump will replace the vaporized fuel. It might cause a momentary hiccup, but not a prolonged loss of fuel. When my car stopped in the pits for lack of fuel, I solved the problem by putting ice on the fuel pump for ten minutes or so. I'll add that the problem has not reoccurred since I modified the pump and added the external regulator.
Tommy
Previously owned EM Cobra
