Old 07-28-2011, 01:53 PM
RestoCreations's Avatar
RestoCreations RestoCreations is offline
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Update: My pump is different from the one in the link posted. I took the pump apart just to get an understanding of how things work, but there is not a slotted washer and seal. I called holley and they said the only thing that would cause a lack in pressure from the pump would be if the bypass valve was stuck, but it appears to be fine. So, next step is to disconnect the return line, block the port at the regulator, and check the pressure with it set up in that orientation. However, while i have this all apart and the tank drained, i need to fix the fuel level gauge first. I swear my to do list is growing instead of shrinking.
