Old 02-05-2002, 06:49 PM
Bob In Ct's Avatar
Bob In Ct Bob In Ct is offline
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Clois:
This is what we know so far - the temp gauge is accurate, the thermostat is in correctly and is opening at 180-190, there is no air in the system. Correct? If so -
A few questions for you -
Does the fan on the radiator turn on? If so, is the air coming out of it cool? If it is you have a circulation problem!
Is the water (coolant) at the bottom of the radiator (the return hose) at ambiant? If it is you have a circulation problem.
Have you tried plugging the heater hoses? I'm convinced if the water pump is moving coolant it's not moving it through the radiator.
Bob
