Old 08-01-2011, 03:10 AM
Snakebit's Avatar
Snakebit Snakebit is offline
Club Cobra Member
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
I used Permatex Hylomar with a dab of The Right Stuff at each end of the crank shaft seals. I am not using a one piece seal, I used Moroso oil pan gasket seals. No leaks. I used the Hylomar when I installed the 2 piece rear main seal and again,no leaks. I had intake gaskets leaking oil and hylomar solved the problem. It's like Franks Hot Sauce, I use that s__t on everything!
Snakebit
