Thread: Cooling Issue?
Old 08-03-2011, 06:56 AM
Bart Carter Bart Carter is offline
Cobra Make, Engine: Levy Racing built FFR w/351W
Everyone is correct on the shroud and the choice of a Taurus fan.
I will add to check your pulley ratios. For the street, you want a 1 : 1.3 ratio of crank pulley to water pump pulley. You need to move more water at a faster rate through the radiator. You will not miss that 3 HP at high RPM.
Also, a properly installed surge tank (not an overflow tank) will purge the system of all air and provide a cushion of air to be a shock absorber for pressure surges.
Bart Carter
FFR 4001
