  #30 (permalink)
Old 08-03-2011, 08:47 PM
Tom Howland Tom Howland is offline
Junior Member
Cobra Make, Engine: 1980 Arntz 427W, Webers, TKO600, Jag IRS
Have you checked all 3 venturi’s to make sure the holes are in the exact same location. I am having problems because my 3 progression holes are not the same. The extra third hole has been drilled in different locations. I.e., 2 o’clock, 3 o’clock, 4 o’clock. I have 4 IDA’s. My symptoms are different than yours. I have a lot of popping when in the idle/transition circuit. Try a fourth hole. If that doesn’t work, fill it and try something different.
Tom
