Old 08-07-2011, 02:25 PM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
If you don't mind doing a little work yourself and have the ability, you can fabricate a set of baffles yourself using the guide on my build page. I had the same problem when using a set of FE pentroof covers on my 351W equipped with the adapter kit I manufacture. I used aluminum roofing flashing. These baffles have worked perfectly for 6 years now without any problems or blow-by. Take a peek at the link below. It just might solve your problem.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
