Im a dwarf, so i put the seat forward and the shifter is in just the right location. The shifter can be swapped around for taller drivers if need be. The location of the actual shifter can also be changed as well. You can see where i reversed the tremec shifter in an earlier post. At least i think i posted those pictures. It's been a while.
Im not real concerned about if it is in the "correct" location for a 427 car. It works well and looks good and that is all that matters. I had the shifter left over from a 68 Mustang build that I ended up selling. Im glad i kept it now.
