Old 08-12-2011, 07:25 AM
Dingocooke's Avatar
Dingocooke Dingocooke is offline
Cobra Make, Engine: KMP180 with 428FE and Crendon 427 with Southern Automotive 462 side oiler
Originally Posted by D111 View Post
what might be the normal or acceptable oil consumption for these type of motors ? small block 400 to 500 hp 10 to 1 compression.
Many years ago, and lets remember, we are talking about old tech iron V8 engines here; Ford in the UK where a 3 litre V6 was a 'big' engine at the time; would not entertain a warranty claim on oil consumption unless it was more that 1 pint per 400 miles; so your quart could easily go in 800 miles and still no warranty claim allowed (oh and UK 'imperial' volumes are bigger than US ones too, so even worse!); and remember all this on very 'cooking' low state of tune fairly low revving standard 'new' engines; not reconditioned and tuned30 year old ones!
To see 400 or 500 hp from a small block, you usually need big valves, more rpm's, more compression, and probably a bore and stroke job too; so you have a lot more crank case pressure variation (increasing blow by) and more opportunities for valve guide and bore wear. I would say two pints in a thousand miles is bearable; my aussie headed 351 cleveland used around a pint in a 1000 miles, and was better on Valvolene than other more 'modern' oils. So that is what is probably normal ? As for acceptable; how much does a quart of oil cost compared to the cost of a rebuild; my guess you can buy a lot of oil for what you would spend in gaskets valve guides pistions etc!!!
I find if you drive faster you don't notice the smoke ;-)
Just my opinon, and have big fun with you Cobra whatever you decide!!
Regards, Steve
We're not here for a long time, we're here for a good time.
My Gallery
http://www.clubcobra.com/photopost/s...0&ppuser=28157
