Old 08-13-2011, 08:47 AM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Originally Posted by Art Burtt View Post
If you are using a coil over suspension do not use grade 8 bolts on the lower
shock mount. If you hit a big pothole like I did last night the grade 8 bolt will snap right off. Use grade 5 or 7.
What about the upper coil mount? Would not both be subject to an equal and opposite reaction?
Unfortunately I have no idea what Jaguar used as bolts for the dual Coilover shock mounts on the IRS. As the length of bolt that I need is dirfferent to the original Jag, I was thinking of machining custom Stainless steel shafts for both the upper and lower coilover mounts. Anyone have thoughts on this.
Thanks,
Arthur
