Old 08-18-2011, 05:31 AM
strictlypersonl strictlypersonl is offline
I've seen rough finishes with both the simple high-temp spray and (bad) ceramic coating. What happens when you sand it? If the sandpaper easily cuts the surface, it's paint. If it's harder to flatten, it's probably ceramic. Either way, the coating should be sandblasted off to bare steel to flatten the surface for the new coating.
