  #21 (permalink)
Old 08-19-2011, 07:26 AM
Paul F Paul F is offline
Senior ClubCobra Member
Originally Posted by bobcowan View Post
Do you need to use gas? What gas do you use?
I don't use gas with my MIG welder, but I can. I know on steel you get a cleaner weld, but so far I havn't wanted or needed to mess with gas.
Metal Inert Gas - that is MIG. By definition, MIG is a process that uses gas. If you are using a MIG welder without gas, you are using wire with flux in it and that is called arc welding. You are stick-welding with a MIG welder. It's just that the stick is now very small and is now a wire instead of a stick.
Gas is much cleaner as it has no flux getting around the weld.
If you are welding without gas or flux, you probably are experiencing really bad results.
