Old 08-19-2011, 10:35 AM
Art Burtt Art Burtt is offline
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
I called Heidts and ordered a new bolt with lock nut and a new aluminum spacer. They sent me the wrong bolt (too large) and a lock nut with fine threads, the bolt has coarse threads, plus the spacer was wrong because the hole down the center of it was too large and it was steel instead of aluminum. Went to Tractor Supply and got the right bolts and nuts (I changed both sides) and I made a spacer out of large washers. I'm still hoping they can send me the correct spacer as it has a tapered end which fits the mount on the Mustang 8.8 rear.
