Old 08-20-2011, 03:56 PM
55312's Avatar
55312 55312 is offline
Cobra Make, Engine: E-M 427 Top Oiler stroked to 482 by KC, Stage 2 heads, a Quikfuel and Voila, 640 hp
15 PSI is not normal at idle when the engine is at temp. My tired old 427 runs 50 to 60 at hot idle (checked it while cruising around today). Cold I'm at 80 with a Melling HV pump. Add a quart or two and check it again before you run around with it. I'm running Brad-Penn 10W 30.
Tim
At first, nothing happened. Then after a few seconds, nothing continued to happen.
Douglas Adams - Hitchhiker's guide to the Galaxy
