Old 08-21-2011, 08:21 AM
SF_SN888KE's Avatar
SF_SN888KE SF_SN888KE is offline
Cobra Make, Engine: Cutting Edge Replicas, 427 World block SBF, TWM Injection
Don't mean to hijack this thread since this relates to eletrical sender ... but
I have a similar problem using a mechanical 2-5/8" SW gauage and Canton 9qt oil pan on SB 347. Big thread fitting of mechanical sensor fits on left side of pan, probably 2" up from bottom of pan. Zero readings. Sensor will not fit oil plug threads at front of pan. (gauage did move off the bottom once or twice - but usually zero)
Thinking of putting new bung at back of pan or using an oil filter sandwitch to get a more accurate reading. Anyone use a sandwitch and temp sensor without adding an oil cooler or remote oil filter? Seems like a big expense to get the oil temp gauage to work. (did that on my other cobra using Earl remote, temp block, etc)
Not worried about the oil temp as the engine runs at 180-190, even in heavy traffic and I don't track the car. just bugs me.
Ron; SF_SN888KE
Cutting Edge Replicas 427
Shell Valley Daytona #27
