Old 08-22-2011, 03:12 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by MaSnaka View Post
Gaz64,I took some ohm readings and this is how they turned out. This is with the sender on a bench one probe on the wire stud and the other probe on the part of the sender that would be in the oil pan. BTW I used a heat gun to heat the sensor and then used an infrared gun to measure the temp.
Cold 72F 8.42
hot 212F 107
super hot 300F 70
I would think super hot would have a higher value.
Let me know what you think.
Thanks,
John
John,
Can you re-clarify your readings please?
Your reading of 8.42, is this ohms or Kohms?
Typical temp senders are all NTC - negative temperature coefficient, meaning as temp increases, resistance decreases.
PTC is temp increase, resistance increase - just like any normal metal, steel, copper etc.
Gary
