Old 08-22-2011, 12:49 PM
Keithc8 Keithc8 is offline
Default 460ci. 428 crate engine dyno results
This engine ran extremely well on our dyno. It made 583hp @ 6000rpm
& 571trq @ 4500rpm. This engine would work well in any cobra application.
This complete package is $11,995.00 with free freight anywhere in the US.
Here are some details on the engine.
428 block baked, tumbled, crackcheked, tapped & fully machined
Stock 428 offset ground 4.200 stroke crankshaft
Scat I-Beam 6.700 Rods
Custom Diamond pistons 10.3 to 1 compression
Clevite & fed-mog bearings
Pioneer SFI Damper
Comp Cams Custom Hyd.roller camshaft
Morel Hyd.roller lifters
Ford Racing timing set
Stock front cover & pointer
Melling oil pump & drive
Moroso T-style oil pan
Edelbrock CNC ported stage II heads
T&D Race series shaft rockers
Comp cams push rods
ARP Head bolts
Original police interceptor PI Intake port matched to heads
MSD Dist & KCR logo wires
KCR logo valve covers
Fel-Pro gaskets
Quick Fuel carb
Bal.to zero blueprint & assm. dyno test & tune
Call Keith craft with any questions 870-246-7460
Keith C
