Old 08-22-2011, 04:23 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
You don't restrict the oil to stock rockers----if they are stock ford rockers, run them like ford built it--no restriction!!!!!
also, if adjusting rockers on a stock type rocker with solid flat tappets, rockers worn at the valve tip contact point will result in an over sized clearance and be noisy at idle---
rockers can be reground on about any quality valve grinder
