Thanks for all the suggestions. I think I'm going with the March brackets and pulleys so i know everything will work together, plus I get the advantage of having serpentine belts. I'll check on the Saginaw pump mentioned in the HAMB forum, Napa part #NSP 816795. Napa does carry this pump and if it's a lower psi then it should work well with the Mustang II rack
